Hey all,
Our firm is finally making more progress into the transition to Revit. I am in charge of basically keep the transition from ACA to Revit as simple as possible. The issue I am having today is formatting a detail (or callout) to fit in an a "boundry".
For example, each of our CAD details templates have a no plot boundary around them to keep them fitting comfortably on a sheet. This template includes the text for naming the detail and showing its file location. Then on our sheets we have defpoint nodes which allow us to snap our details so they are always in the same place. My issue is in Revit when a detail is created, then placed on a sheet, the title has to manually be moved and each detail has to be adjusted to fit in the assigned detail spot.
If anyone has any info or needs me to clarify on anything to make this question easier let me know!!
Thanks
Thanks
