Projection Patterns and Lineweights on Floor surface
    I have a problem with overriding surfacepatterns on Floors. The lineweight becomes 3 instead of 1 on the projection pattern. It doesn't matter if it's override by category or element, even filters use lineweight 3 So far I have only seen it on Floors. Overriding Roofs an walls projection patterns, uses lineweight 1.
    Could someone confirm this behavior.
    - Peter -
    www.revitogbim.blogspot.com
    Not a lot of help, but I've tried changing the surface patterns of roofs, walls and floors, and they all seem the same lineweight, and it isn't 1.
    Maybe I am not understanding exactly what you are doing?
    William Sutherland rias riba
    WS Architecture Ltd
