I'm having a material rotation issue. I have some sloped walls which I made using the Wall By Face tool. I need to show a stone material on them. When I change the visual style to realistic, the stone is rotated vertically on the surfaces (as you can see in the attached image, it displays correctly on normal walls). I tried to solve this by editing the wall and changing the material to brick so that I could rotate it, but then the brick displays correctly. That one really baffled me. Any ideas on what could be causing this?
I suppose I could just duplicate the stone material and rotate the .jpg by 90 degrees, but I'd really like to figure out what is causing this. Thanks for the help.
