this should be simple and probably is but I'm struggling with making an offset rod door pull. I'm in a face based generic model template and I am only able to sketch a sweep path in one plane. As soon as I sketch the start of a path in one plane Revit won't let me sketch in any other plane. There's gotta be an easy way to do this.
3D sweep path?
To the best of my knowledge this is still a software limitation. You can sweep all day long in 2 directions but a 3D sweep is something still on the wishlist.
EDIT: I take that back Aaron mentioned a sweep along 3D model lines over here
Originally posted by eric.piotrowicz View PostTo the best of my knowledge this is still a software limitation. You can sweep all day long in 2 directions but a 3D sweep is something still on the wishlist.I'm retired, if you don't like it, go around!
Sure it´s possible - even with a single sweep.
The trick is to create the path as model lines (create and name a few ref. planes, and use those as workplanes for the model lines) and use those model lines to "Pick Path" for the sweep.
Have a look at this example, and reverse engineer from thereAttached FilesKlaus Munkholm
👍 1
Munk is right. Doing 3D sweeps in Revit almost always requires you to first make a 'jig' of model lines or from another solid of some kind, then using the Pick Path option to make the path.Jeffrey McGrew
Architect & Founder
Thanks guys,
learned smth this day. this forum is really the place to be.Julien
P. DAC
Here is what I'm trying to achieve.
I couldn't get the path/sweep to follow the 3D model lines that are shown in the isolated...February 26, 2015, 09:09 PM -
Hi
Is it possible to create path in different axis in Sweep.February 14, 2017, 10:39 AM -
Just to make sure, there is no automatical way to extract this information, right?September 3, 2012, 08:17 AM
Don't know how to explain it properly, so I'll post the family (work in progress). Have a look at it first, it's a concept of what should become a fan...
July 22, 2011, 05:28 AM -
Hi guys, I took Revit class about a year ago and now I'm trying to refresh my memories and use revit again.
However, while I was taking...-
April 11, 2011, 02:26 PM -
Monumetric Footer In-screen
