Wedge shaped foundation wall
    Does anyone know how you would draw a foundation wall that is wider at the bottom than the top. It is for an as built of an older house.
    Appreciate any tips.
    Thanks
    Chris
    You could try a couple of methods:
    1. Create a "normal" 90 degree wall, then add a sweep with a custom profile that would give it the taper/wedge shape.
    2. Create an in-place family in the Wall Category and model it with the desired shape.
    3. Make the wall the thickness of the widest point at the base, then use a Void and Cut Geometry?
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
      do you need to do any structural load calcs or analysis on the foundation wall? if so that will make a difference on how you create it.
      Robert Szudzik, LEED AP
      Architectural Designer/BIM Manager
      Wendel Companies
      Buffalo ~ New York Metro ~ Washington DC ~ Richmond ~ Minneapolis ~ Phoenix
        I am also searching for a way to do this when using a wall foundation. I don't need a quick way but the best way. What would be the proper way to do this then?
          Couldn't you also use a profile on a slab edge? Assuming there's a slab above the wall.
          Dan
