Can you enclose text with a circle like in Autocad?
    I need to annotate a drawing by adding numbers 1-5 then enclosing them with a circle. Can I do this?
    Domsib
    Revit MEP - 1 Day at a time...
    Only if you create a Generic Annotation family and put the circle in the family. Other wise it's just text with a separate detail line circle around it.
      You might also investigate Note Blocks, Tags and Keynoting.
      Cliff B. Collins
      Registered Architect
      Autodesk Expert Elite
        I was a$$uming the OP just wanted text, but you are right off course. Text and Keynotes can be fitted with a circle too.
          ①②③④⑤
          Like this?
          "I WANT SOUP! This fork is useless! I'm going to use my spoon for everything."
            IMHO you should always do it as a family. What do you need it for? As martijn and cliff intimated, you can leverage some intelligence from Revit if you use generic annotation or tags. I make it my mission to avoid text.
            `Employ your time in improving yourself by other men's writings, so that you shall gain easily what others have labored hard for'
            Socrates
              Cliff - I understand how the Tags and Keynoting approach would work but I'm not sure how you would get a Note Block with circles. Would you provide a short description of that?
              Joshua Kohl
              Eastern Exterior Wall Systems, Inc
              www.eews.com
                Doing this through a Note Block means making Generic Annotations, like Martijn said earlier.
                I've made a quick example:
                  I understand the NB will pull the information from the GA but the NB itself wouldn't create the text enclosed with circles.
                  Joshua Kohl
                  www.eews.com
                    The Note Block itself is really just a "schedule" so it will not have the number with a circle graphic. It would be a table with the number and associated note. The generic annotation family placed in the view would be the number and the circle.
                    Jeff Hanson
                    Sr. Subject Matter Expert
