[04/2011] - Make all popup windows resizable
This is a sticky topic.
    Applies to: - All Verticals
    New Feature / Problem:
    Popup windows are sometimes to small to read the contents. When you can select custom names in a window. The columns are often to small, and when you widen the colomns, you can't see all the columns
    Examples are the:
    Edit Assembly Window,
    Edit Railing Window,
    Edit Baluster Placement Window.
    Quickly edit info, have an overview of all the info.
    Workflow:
    Drag the window border
    Benefits:
    faster workflow
    Attachment comments:
    Sander Obdeijn
    Support Engineer
    ITANNEX [Autodesk Gold Partner]
    Personal Mailadres:
    [email protected]
    General Support Mailadres:
    [email protected]
