Just open Keyboard Shortcut UI in 2012 then down the bottom hit the import button button and path your way to your 2011.xml file. When asked to either "merge or overwrite" pick "overwrite"
i have problem really that every assigning do not work with me only default i tried to add beside default did not work with me i tried by removing default...
