Revit and Text
    Revit and Text
    As we are all painfully aware, Revit has pathetic at best text editing capabilities. Please post some solutions you have come up with. Also explain your success or failure with these solutions.
    -Alex Cunningham
    General Notes:
    We have implemented, only for large bodies of text, the use of linked DWG files. AutoCAD is much more capable of handling the formatting of paragraphs of text and bulleting.
    We have all our general notes and specs in a Word document for easy editing. This is then copy and pasted into AutoCAD, refined, then linked into Revit on a drafting view and placed on a sheet.
    We keep these notes project specific by keeping them in the project folder.
    This way of doing things is laborious for the drafter. However, by using word our Project Managers are able to make the required modifications to the notes and then the drafter is tasked with getting them into Revit.
    You will also have to send any DWG files with the RVT file.
    -Alex Cunningham
      I do my large content notes, like General Notes, in Excel. Sort of the same process as yours but I use XL2CAD from dotsoft.com to link the file into Acad which is in turn linked into Revit and added to a drafting view. This way any changes to the verbiage in Excel is automatically updated in Revit. This has worked well for me in my short experience.
        We do all of those things in extra key Schedules that we dont use for anything else. Its in Revit, you can type in Revit. It word wraps paragraphs, etc. There are a few limitations to it... But (though this sounds harsh)- ive never had a problem getting a good and readable set of drawings out the door with it. A lot of people want fluffy text editing (and i guess i can understand it), but the more we move towards intelligent tags, Smart Keynotes, etc... I just dont need much from a text editor.
          I have tried both the suggestions above, but for quick accessable notes that users of all levels can edit straight text is the only system that users can work with . Obviously use of model data with tags etc is first choice, but for specification type notes they need to be easily editable on my projects.
          Something I have found useful is creating families for tables which can be preformatted and kept consistent. For tables in specs it saves a lot of time, and keeps formatting consistent
          Revit BLOGGAGE
          http://www.revic.org.au
            Has anyone else been having problems with Revit text columns jumping around and resetting after editing text? You can get a paragraph of text looking just the way you want it only to have it get reformatted in a weird way the next time you you finish editing it.
            Scott Hopkins AIA LEED AP
            Peikert Group Architects
              Yes, I have had that issue for awhile now. Every now and again it changes the formatting of the text for no real reason. I then am forced to resize my text box to get it back to the way it was. One of those Revit issues I have learned to put up with. I don't like it though.
                Any word or experience about text generator extension?(subscription pack).
                Julien
                P. DAC
                  So Sad
                  This is such a sad post.
                  These workarounds only drive home how unfortunate the text handling in Revit is.
                  And that for most of the needs we have, there are no workarounds that don't involve a lot of brain damage.
                    What kind of category to you create your general notes key schedule under?
                    I picked a Switch System, as I'm guessing I'll never use that in my Architectural model...?
                    My first thoughts on this method of doing General Notes is pretty positive. I really like the ability to change the column widths and split the schedule and have everything automatically adjust. Pretty slick.
