playing around
    playing around
    Hi All,
    Just impressed myself with how good revit is so thought I would share. Currently modelling up an existing house and site. All very much work in progress so no real detail to the landscape yet, but it is nearly ready to make some alterations to the house and significant improvements to the garden, but not bad all the same!
    Will post some of the updated and more detailed existing, and then proposed stuff when ready.
    Regards,
    Max
    the shoe was the sign.....
    Excellent work, Max.
      Sweet!
      Although one remark: you should model the antenna on the left chimney, that would be hilarious...
        I very nearly did......I have done before on a different job
          Do not be too impressed with this technological terror you have created...
          Good stuff.
            ....and the proposals. Thankfully the client loves it! low quality images, took about 5 mins each as they were hot off the press prior to my presentation to the client!
              some higher res externals, and lower res internals
                I'll take one too. C'mon across the pond and throw that guest house up in my back yard. :laugh:
                Is the rippled water an OOTB Revit material? If not, where did you get it (or how did you make it)?
                Dan
                  Hi Dan. Thanks, and yep, straight out of the box.
                    The only thing I don't like, but its a general Revit thing is the skies. They should be a little less "muddy looking" Other than that awesome renderings
                    Juan Carlos Moreno
                    Sisley Cosmetics
