Revit 2012 - little gripe - Type Properties dialog
    Just a small gripe with Revit 2012... (2011, 2010 etc...)
    Is there some technical reason that you cannnot resize the Type Properties dialog?
    William Sutherland rias riba
    WS Architecture Ltd
    I think it has always been like that. I wonder if they have done something about the other issue, that the content of the dialog gets shifted to the left when you click inside?: see http://revitforum.org/showthread.php...full=1#post913
      I haven't tested 2012 to see if they have fixed it but I HATE that
      Juan Carlos Moreno
      Sisley Cosmetics
        Thanks for the link.
        No, it still does that annoying shift over - drag the column edge over so that the window slider disappears and it doesn't happen - no change at all from earlier versions.
        Of all the dialog boxes in Revit, surely they could have spent a bit of programming time in allowing this one to be resized?
        Obviously not
        WS Architecture Ltd
