It used to be when you added a wall sweep to the wall, it would automatically cut at openings and if you need to adjust it further there were little blue dots at each opening. These are there if the sweep is part of the wall assembly, but not if you use the wall sweep tool?
Wall Sweeps Missing Endpoints for adjusting
Scott D. Brown, AIA | Senior Project Manager | Beck GroupTags: None
When using the wall sweep tool, if "Cut by inserts" is active in the sweep's type properties, you do not get blue dots at the openings; if it is not active, you do.Freelance BIM Provider at Autodesk Services Marketplace | Linkedin
I created a family for my drop box. The family only cuts the sweep where the trim around the box is. The center doesn't cut. I used a void for the...
January 20, 2011, 04:50 PM -
what is the difference between cuttable and cut wall options in wall sweep?September 29, 2012, 10:39 AM -
can u cut a wall sweep with a void or is this not possible...January 10, 2014, 03:52 PM
I have a long thick wall with a few openings on it. I am trying to get the sweep to return inside the openings without breaking up the wall. I have tried...April 27, 2018, 09:04 PM
I am not sure why this sometimes happens with wall sweeps. There are like, 6 nodes. I just want two so I can drag either end and have it stretch to to...December 11, 2017, 05:59 PM
