Since the GPU portion of the RFO Benchmark is just for information only....thought it would be fun to post results from a GPU test. UNiGiNE has a new Valley Benchmark test.
Just to make the test simple, select the Extreme HD preset and select RUN....
When your flying through the test, it doesn't actually start until you select BOOKMARK in the top left hand corner.
Post your results when finished. (BTW, after its over, change the camera to Walk mode....way cool....wish it had mouse movement though instead of the arrow keys)
