Roof slab not showing up
    I cannot get my roof assembly to show the proper layers in my 3/4"=1'-0", it only shows the outline. My detail level is set to fine, all other elements show up properly except for my roof. Any thoughts?
    Hard to tell without having the file to mess with. But it could be related to a bug in 2011, as in this thread.
    The bug should be fixed in 2012, so you could try to update the file... or make a copy of the file, and delete+purge everything unrelated, and upload the file here. :beer:
      I can't see the picture (it gives me a " you're not logged in" error), but have a look at your Rafter Cut and Fascia Depth. I have seen this behaviour with sloped roofs and a Plumb Cut too.
        Ok so I could only get the file to 6.3mb, so I had to upload it to dropbox.
        http://dl.dropbox.com/u/3060856/roof%20test.rvt
