Architrave, Entablature Pediment
    What is the best approach to create classic architrave, entablature in a pediment? I also need to know how to create a cast stone profile that is at the head and jamb of a window.
    Basically, anything that is not already an out of the box Revit family, must be modeled. There are 5 basic methods: extrusion, revolution, sweep, blend, and swept blend. You need to find the 2D profiles that make up these architectural elements, and create the solids, either as families or as in-place objects.
      If it's any help..
      Not for the proportion purist perhaps but I've used Haddonstone cad profiles to sweep moldings and other classical parts:
      http://www.haddonstone.com/CountrySelect.aspx
      William Sutherland rias riba
      WS Architecture Ltd
