I am trying to tag curtain walls to create a window schedule, and I can only get the wall type tag to show up. Is it possible to tag curtain walls with window tags instead?
Tagging Curtain Walls as Windows
Originally posted by stl4310 View PostI am trying to tag curtain walls to create a window schedule, and I can only get the wall type tag to show up. Is it possible to tag curtain walls with window tags instead?I'm retired, if you don't like it, go around!
There are a ton of things to think through regarding this:
Curtain Wall "Types" wont correspond to any actual type of mullion configuration or elevation, so in effect: Either way you do it will be manually coordinated. Since that is the case, i recommend a Generic Annotation placed in a Model Group with the Curtain Walls. At least then you can select all of the model groups, and tell them to place the attached detail groups in certain plans. Its manual that when you make a new curtain wall configuration (group) you have to change the GA, but thats no more manual than having different Curtain Wall "types" since they wont associate anyway.
Originally posted by stl4310 View PostI could do that, it's mostly a graphic thing...
Originally posted by stl4310 View PostI guess to create my window schedule (multi-category?) I could create a filter to include curtain walls?
Hello,
I'm about to ask something as a beginner and hopefully, you will help me...
Revit allows usage of something defined as...April 12, 2017, 12:49 PM -
Hi everyone, i have a question how i can save curtain wall as family or make it be used in different parts of my project?
can i schedule curtain...December 2, 2011, 12:12 PM -
Is there a way to tag curtain systems?
I can't seem to find a tag that will work.May 3, 2013, 08:25 PM -
Working on a multi tower residential building. I'm working through the podium level windows which are punched curtain wall windows and I'm grouping all...May 22, 2018, 02:48 PM
Reviteers,
I belive I have to use a multi-category tag to tag a Curtain System. I am familiar with shared parameters and family creation....December 15, 2011, 09:43 PM
