Just Starting with new Revit LT 2013
(The Comparison chart from Autodesk lists the differences between LT and Full Revit as no Massing, Rendering and no multi user collaboration) Everything else should be the same!
I'm using 'LT_USI_Residential-Default' Template for my project.
In the Stair Family, I have a few options, but not the '7"max riser 11" tread' stair that is available in other Templates.
Is there a way to bring that Stair Family into the Template?
Maybe I don't know the 'workarounds', but none of the Stairs available in the above Template have changeable 'width' parameter under 'Dimensions' in the properties window.
No matter what I do, all Stairs are first drawn 4' wide, and then I have to edit the width, but it's a pain since I get bunch of error messages and Landings often can't complete and needed to be manually added later.
Even though the Type Properties list all stairs widths as 3' min., they still all draw as 4'.
What's wrong with these Stairs?
