Area and Longitudinal Reinforcement
    Dear All,
    I have faced two problems in revit.
    1- When I model the longitudinal bars in a column (pretend 8 bars), in the rebar schedule the revit does not given them as a total and adds a row for each of them in the bar bending schedule. How can I group these 8 bars in the bar bending schedule. (one row with the quantity of 8)
    2- The area reinforcement is not included in the rebar schedule. Is there a way to make revit include this or not? If not, any add-in or something else please (my revit is 2011).
    I would really appreciate your help
    Wish you all the best
    Ali Akbar Shaikhzadeh
    for point 1, you should use a parameter to identify them as part of this column (mark, comment, shared parameter...) and sort them with this parameter in the schedule properties.
    for point 2, you should add a calculated value s.a. "estimated reinf. vol. / total length" to report the total area of vertical rebars (and only for them) for this column.
    Julien
    P. DAC
      Dear jbenoit44,
      Thanks for the information. To tell you the truth, I could not catch you what you mean for point two. Can you please explain more.
      Warm regards,
      Ali Akbar
        Ali,
        What you need to do is go into the Formatting in your schedule then go to your quantity and make sure that "Calculate Totals" is checked. Also in Sorting/Grouping make sure "Itemize Every Instance" is unchecked.
        I do not belive Area Reinforcement can be scheduled...thats why most just use the rebar tool rather than the Path/Area Reinforcement...
        HTH
        Grant
          Originally posted by Ali Akbar View Post
          Dear jbenoit44,
          Warm regards,
          Ali Akbar
          Maybe I misunderstood. Do you mean area reinf. - the tool in Revit; or the area of the reinf., meaning the total section of rebars in one section of an element?
          My answer was about the second point. As Grant said, Area reinf.-the tool- is just a 2d trick for documentation.
          good luck.
          Julien
          P. DAC
          Loading...
