how to darken fill pattern
    hi, i was wondering how to darken a fill pattern? i attached a picture below.
    the pattern was a hatch i found online. i tried modifying it, but have been unsuccessful in darkening it. i was able to change its color but thats all. i attached another picture to show what i did. how can i darken it?
    thank you
    You can change the colour - change it to a darker shade. It's under "surface pattern"
    Unless you're meaning something else.
    "I WANT SOUP! This fork is useless! I'm going to use my spoon for everything."
      If you're talking about making the lines thicker, I think material patterns are hardwired to lineweight 1 from the factory. Filled regions can be assigned different lineweights if that helps at all.
        Think its 1 or 2 now....
          It is 1 for all non ceiling patterns. Patterns in a ceiling will use 2. How very last century such limitations are.
          Gordon
          Pragmatic Praxis
            Knew 2 was used for something....couldn't remember what...
              hi, where is it under surface pattern? ive changed the color rgb to 0 0 0, pure black, however it continues to look like light gray.
              i attached 2 more pictures of it. i feel like this should be a simple thing, but i cant figure out how
                Pen weight #1 is what controls the thickness of model lines....so check the scale of your view and then look at what your line weight is for Pen #1....
                  Yep, what you have done is correct.
                  Do you have any overides turned on ?
                  Select roof, right click, select, overide graphics in view/ by element and hit reset.
                  Mark Balsom
                    do you think it has something to do with the .pat file?
                    i have tried resetting and even explicitly putting everything to solid black, but yet it appears grey. i attached a picture below. is it the way the .pat file is written?
                    i attached the .pat file as well. can the .pat file be selecting grey as the default color?
