So i downloaded and installed 2012
I borrowed from a friend a 3dconnexion Space Navigator to see what is the filling to navigate through your models.
I have a question. The navigation is very tricky because I can`t change the settings from Object Mode to Camera mode or other options . Now all the model is rotating around the pivot point that is the center of the model or the center of a selected object). The same behavior like oribiting by cube. It`s very annoying. The menu for changing this is showed in the attached picture but it isn`t show up in Revit. So it`s not so fun in object mode (i think this is the setting now). I installed the 3dconnexion driver before revit 2012. Is this a problem?
Can somebody give me some advices?
In the mouse help for Autocad, they say that the driver install some buttons in UI for changing the navigation mode. This makes me thinking that maybe i have to reinstall the driver so the it can add some buttons to Revit UI (now driver was installed before Revit)...
