Looking for the post regarding cad files moving when project is reopened
    I've tried searching and can't find it. Someone recently posted why a cad file with acquired coordinates will rotate when the file is reopened.
    Hi Scott,
    Is http://revitforum.org/showthread.php...-North-issues? the one your after?
    Ian Kidston
    http://allextensions.com.au
      Still Looking
      No this isn't the one. Someone did a detailed description of what happens when you insert into a view set to true north vs project. And how it affects what happens on re-opening the project.
        Perhaps This one?
        Juan Carlos Moreno
        Sisley Cosmetics
          Not the one
          Nope, maybe it was on AUGI. it outlined what happens after you bring in the cad survey, rotate move and acquire, then save. then when you reopen the dwg is off in space somewhere.
            Maybe this thread then...
            If that´s not the one either, then remember that you can use Boolean Search on the forum, e.g.
            survey AND reload
              Not that one either
              Thats a great post, but not the one. Thanks.
