Some doors doesn`t mirror with spacebar when placed. Usualy this is a good thing. For coordonation. I mean, you have to make one more step to press the blue arrow after the door is placed, so this way MAYBE you remember to check a custom parameter like Mirrored Door.
With the spacebar mirroring you can forgot about initaiate this manual coordination procces.
Anyway, the question is why some complex doors can be mirrored with Spacebar placement and some not.
Example:
Klauss door doesn`t work with Spacebar (the RFO Door that is in the Download section)
Door_Single_Gen_RFOSG_WH - Downloads - Revit Forum
Aaron`s door works.
bouth of them have nested families and bouth make use of nested families that can be changed.
I also have a door that behave like Klauss one.
I`m happy that I can`t use Spacebar. But i just want to find out, what make them to behave different. So we can contro11 that.
second question:
How are you hadles these days the manual coordinations for mirrored doors, so we can schedules correctly. I remember it was a script in the past somewhere this forum.
Example:
Aaron`s door works.
second question:
