Edit Curtain System from Mass
    OK..
    I thought I had done the hard bit.. creating the mass, shaping it, and applying a curtain SYSTEM ..(not WALL) to the face.. Job done..?
    Now all I want to do, is create some mullions etc, in the areas where I want them.... I can create the vertical ones, but the horizontal ones are driving me barmy.. I can add a grid line in, but I have no way of actually giving them an accurate dimension..? It does not at any point allow me to type or amend a dimension..?
    Attached is the mass and the situation I am trying to solve..
    Any ideas, greatly appreciated....
    AndyClick image for larger version
Name:	Curtain wall 01.jpg
ID:	403465Click image for larger version
Name:	Curtain wall 02.jpg
    I learned long ago, never to wrestle with a pig. You get dirty, and besides, the pig likes it
    Not sure why you are not able to dimension curtain grids right away... just made a quick mock-up and it´s working fine here...
    Anyway, create horizontal ref. planes where you want the grids, and use align to place the grids on the ref. plane - that should work :beer:
      Klaus,
      Once again, to the rescue..
      I am learnig to love ref planes.. they are a revit'ers best friend.. ;-)
        One more question..
        I need to apply a basic wall to the same shape as attached above, but at the first floor level.. Problem is, when I use pick face, it wont actually slice the angled piece off of the left hand side.. The curtain system works, but the wall wont.. I am a little stuck..
        Cheers
          OK..
          If any one can confirm or deny this..!
          I have re-created the shape I am trying to use as my basis for the external wall. The one shown above is a solid extrusion, from the base up, and then I have created a void piece and taken it away to get the splayed end on the left. This front face will not accept a wall in the same shape as the face. It will not splay left edge to line up with the shape.
          If however, I re-create the shape, and manipulate the edges / points to line up with the shape above, it will accept the wall in the same shape as the face. I.e. this shape is one piece, as opposed to a solid and a void.. Is there a reason for this, or is this something wierd going on, or have I done something wrong..?
          Cheers..
