Mass geometry
    Mass geometry
    I need some help about a mass geometry i can't build in Revit. See the ataached file. It is a form like this i need to build. This one is made with help from a Rhino geometry. But i would like to build it in revit my self. The only thing that teases me, is the sloping surface on approx. 4.65 degrees. I can't control the points and the slope at once. And if i uses voids, the roof is getting wrong.
    Please help me :-).
    (if you can't see the mass, tun it on.)
    Here you go. The mass with the red color is made from scratch in Revit... Didn´t join the two pieces, so you better can tell what I did to create it.
    You owe a cold :beer: !
    BTW: The heights are those from the image in the message you sent me.
