Door Schedule hiding Rows
    Is there a way to remove unwanted doors from a schedule with deleting them? I don't want to show my demolished doors in the schedule.
    Hi Redmonki,
    The simplest way that I have found is to re number all of your new doors with an identifier, - I use the letter "d" Thus d1, d2, d3 etc but you could use any other identifier.
    Then filter the schedule to show only the doors which contain the identifier. Same for windows
    Ian Kidston
    http://allextensions.com.au
      Set the Phase Filter to Show Previous and New??
        You can make a filter for a door parameter in door properties, I use "Comments" or make your own, in comments I type "demolished" then create a filter for "Comments" to hide all doors with a "Demolished" "Comment" parameter.
        Mark Balsom
          :thumbsup:
          OK Aaron you win (again !!) and today wasn't wasted I have learn't somthing new.
          "Phase and Phase Filter" to sort Schedules,
          seen them there and it never registered :thumbsup:
          Mark Balsom
            Do I need to set up the schedule to respond to the phase filter? because changing the phases or filters doesn't seem to affect my schedule. FYI my 'new' filter has demolished set to 'not shown'. Shouldn't this remove the doors from the schedule?
            I will try Mark B's version. Thx
              Cheers Mark works a treat.
              Still working on that line work prob.
                It is certainly interesting to see how people achieve the desired result in different ways.
                As inevitably I need to renumber my windows and doors due to the chopping and changing of them during the design process, I settled on the identifier / filter option as being the most appropriate for my work flow.
                Ian Kidston
                  Got it Twiceroadsfool (Aaron?). Definitely quicker.
                  I missed the obvious.
                    Mark, I'm curious. In your image, it says the Door is Created in New phase and also Demolished in New.
                    Should it be Created in Existing and Demolished in New?
                    All - Aaron's solution is the correct one (as usual), but in general, one other thing we've done is to add a Shared Parameter we call "DoNotSchedule" and make it available to all Categories. Then our Schedules filter that out. It's NOT the right answer for Demolition, but we end up using DoNotSchedule for all sorts of other things - Equipment supplied by Owner, Door Panels reused, Furniture N.I.C., Rooms that shouldn't be calculated.
                    It's kind of a catch-all when it's difficult to use something already built in to Revit.
                    Dave Plumb
                    BWBR Architects; St Paul, MN
