Slanted columnn issue
  • jh75
    Thanks mate,
    For some reason it didn’t cross my mind using Ref lines - it solved the issue with having a slanted column.
    When changing the Base Cut (or Top Cut) from Horiz to any other option the columns go funny again – but I can live that.
    Thanks again for looking at this,
    Jh
  • alexo4141
    Originally posted by jh75 View Post
    The column is made up out of 3 different sweeps.
    What I did is to replace your main sweep by one that follows Reference lines instead of snapping to intersection of reference planes. Just tested it with a end point driven slanted column and it seems to work fine.
    I'll let you go through the whole testing process.
    HTH
  • jh75
    started a topic Slanted columnn issue
    I have create the attached column. It works ok when vertical but when I changed it to slanted it goes all funny – see attached image. The column is made up out of 3 different sweeps
    Any suggestion on what might be wrong would be much appreciated.
    Thanks,
    jh
