When i draw in section arrows on a plan, they appear in every other plan in my model file, i understand i can hide the section arrows from the other plans manually, but is there a way of making the section arrows automatically not appear in other plans but only the plan you draw it on?
Section Arrows in 1no. view only??
Craig, the main question is what is the decision making process behind turning off this particular section, and can it be automated? So, if this is a wall section, and you only want wall sections in certain views, then you can create a dedicated Wall Section section type, and use filters and view templates to turn all wall sections on or off in different plan view types. Another example is vertical circulation sections, which I only show in vertical circulation plans and other vertical circulation sections.
But, if this is an odd bird section, that you want only shown in one plan, things get harder. Then again, Details offer a little more flexibility in this regard, and maybe this view is better off as a (section) detail?
Gordon
Hey, i hope im phrasing my question clearly- is there a way to select what type of section marker appears in the plan views for each individual section?...June 23, 2014, 01:36 PM
Hello All
I have created a section view and detailed as I needed to, I then created a duplicate view as a dependant. the only difference...-
January 25, 2012, 05:30 PM -
Howzit guys,
Can someone tell me how i can create section marks on only my "duplicated views", so that they don't pop up on all...-
August 14, 2014, 01:24 PM -
I have asked on other forums but no one can answer my question so far, that of "The Missing Wall Section Icon".
1. Go to the Create...January 5, 2014, 11:09 AM -
Hello,
I have placed a series of wall sections along a building section. The wall sections all have the same view template applied. The issue...July 7, 2014, 08:51 PM
