Hi All,
Has anyone reviewed the calculation side of Revit MEP 2011?
Particularly the Heating and Cooling load calculations that it can generated. Are the results creditble with such apps as Carrier HAP or Trane? It seems just a great idea that after the architect generting the model and us creating spaces with default values we can run a design thermal model inside Revit MEP.
Does anyone know the 'engine' that it uses to undertake the heating and coolomg cals? I know in Revit MEP 2008 it used to be IES VE plugin. But I dont see the IES logo anymore.
I have been experimenting with gbXML outputs to Carrier HAP, but seems the transfer is quite poor. And very limited geometry is being pulled across. A lot of the metadata is lost.
Any feedback would be appreciated.
Thanks.
Thanks.
