I have created a topography surface in the site view. I used a autocad file. The surface was created and I can see it in all the views except the 3D view. I have checked nothing is hidden. The imported file shows as a vertical line in the 3D view.
topography surface created by imported file not visible in 3D view
Hi Anjata, and welcome to the forum.
I´m not quite sure that I understand what you´ve already done... Have you created a Revit Topo from the AutoCAD file, or are you using the cad geometry as your Topo ? Could you elaborate a little, and perhaps include a screen shot or two ?Klaus Munkholm
You should see your 3D Cad import as contours or a TIN in the 3D view, if you are only seeing a vertical line, creating the topo would not be possible, as it doesnt sound like your 3D CAD survey imported properly
Topographys will be turned off by default in the 3D view as well, so double check the VG graphics again as well
following to this topic. I have a slight problem with this topography. i received a site survey in CAD 2D and I would like to plot it now in Revit. I don't think I have the Z values table in there tho.
These are the steps I have taken to produce my topography, please correct me if I am wrong, or can be done quicker:
1. linked / insert cad
2. rescale
3. massing & site > topography > pick points (so here i type the elevation on every points and click it there)
am i correct?
Originally posted by joss View Postfollowing to this topic. I have a slight problem with this topography. i received a site survey in CAD 2D and I would like to plot it now in Revit. I don't think I have the Z values table in there tho.
2. rescale
am i correct?Klaus Munkholm
Originally posted by anjata View PostThe imported file shows as a vertical line in the 3D view.
the vertical line might be a distorted view of lots of point in the top connecting to a lower (if not more) point below.
Try editing the surface in 3D end deleting the wrong one(s) in the same 3d or elevation view.
You can also check the problem in planview for very dense contour lines.
Hope this is the case...
And Klaus, go to bed!Last edited by feio; February 10, 2012, 11:25 PM.Gonçalo Feio
little more problem
im stuck! i would really appreaciate it if i can get some help here in creating and positioning my toposurface. On attachment there is my csv. file I extracted from autocad for the x,y, z points. I uploaded to Revit using toposurface >specify points files > and bam! it's created somewhere else so off the site.
My question is, how do I align it up with the original toposurface to the building?
On the 3D view, west side of the house, there is a big hole... I am sure the land doesn't look like that.
Am I doing this correctly?
Thank you. please helpAttached Files
Hey all,
Having an issue in Revit 2015 where a toposurface (created from a .dwg import) shows up in all views EXCEPT 3D view. I can see (and...February 4, 2015, 07:29 PM -
Hello all,
Have you all run into this issue? We always have a constant need to build a topo surface for the project site model in the office....August 23, 2012, 03:36 PM -
I am linking an AutoCAD file to my Revit Model to create a Topo Surface. I have gone to Massing and Site / Topo surface, but when I click on Create from...October 31, 2016, 09:38 PM
For the life of me, I cannot seem to figure out why my toposurface will not show up in the default 3D view in my model; it shows up in all my other projects!...September 10, 2013, 11:51 PM
I have a dwg file of my topography that I brought into revit and I followed the steps to create a topographic surface from it but it keeps crashing revit...March 8, 2018, 02:49 AM
