getting columns to show up in Graphical Column Schedule after move.
    So, the architects changed the elevation(s) of the floor levels last night. I moved my project up 32' to match. However, I got a warning that said that 42 of my columns no longer are visible in my Graphical Column Schedule. The 42 that are missing are at my very top level, spanning between my Roof and my PH Roof. How do I get them to show back up?
    Leanne Zaras, CDT, LEED AP
    (here I go talking to myself again...)
    Nevermind. I figured it out.
    When I moved my levels up 32', my column grids didn't adjust. I had to go into each elevation view and drag the column grids up.
      Hi Leanne, just for the record, do you mind explaining maybe with a screenshot? I'm interested in your issue, but didn't really catch the full sense.
      Thanks
      Julien
      P. DAC
        Doh, good catch. Ill keep this in the back of my head if I come across the same problem. Thanks
        -Alex Cunningham
