Can anyone tell me which parameter to add to a mechanical family so that its value appears in the Actual heating load cell in a space schedule?
I am trying to create a hydronic supply/return radiator which will have an output in (W) and I want this to be taken in to account with regards to the Calculated heating load in the same way as the Calculated/Actual Supply Air works when you add a diffuser to a space.
Thanks
Rob
Thanks
Rob
