I'm not sure if this is possible, but it should be.
I'm creating a scissor lift family. I have the lift runners as a nested component so it can be raised and lowered. The members under the lift that do the lifting will need to change angle as the lift raises. One end of them will also have to slide along the bottom of the lift runners and the base. Is that possible to do?
