how to creat this family?i tried by sweep but not success..can you help..please
    Family c
    easiest thing I can think of is a series of extrusions and blends. a sweep will break on the tight corners, although you could sweep a rectangle and use voids to cut the corners.
    chad
      My attempt.
      Not 'parametric' as such, though your could make it so quite easily...
      I used to be high on life, until I realised it was cut with Morons.
      Combating ignorance daily through learning.
        thanks so much
