Regions
    Regions
    Hello
    I have a problem with my regions in my details when using drafting fill patterns. If the hatch represents a wall placed in 45 degrees, my hatch will not align despite i have told it to do so. The problem only occurs with drafting fill patterns, the model fill patterns are working okay...
    Can anyone help me??
    /Mads
    Welcome to Revitforum, Mads, you are our 1,000th member! :wine:
    Then use Model hatch patterns instead of Drafting. I suppose the reason for the issue is that Drafting patterns do not recognize model orientations.
      member number 1000 :-)
      Okay, i will do that.
      Thank you.
        Mads, congrats on #1000!
        You should report this problem to Autodesk as a bug.
        More bug reports = Better chance of getting it fixed.
          The problem with model fill patterns is, that i can't make them fine enough. A min. line distance for a crosshatch is 12-13 mm. i would like a distance about 5 mm in my 1:5 details.
          Any suggestions??
            Where can i report it??
              Use the "Product feedback form" found thru this link :beer:
                Using model patterns in a 1:5 scale means you'll have to make them 25mm wide. So you're good there. Be aware though that model patterns are indifferent to scaling. On a different scale, the pattern will not adjust.
                  Mads, you are probably on subscription, so sending a Support Request thru the subscription center might be a better option. :beer:
                    yes and i have send Autodesk a support request :-).
