Hi Guys
I'm coming acorss an Issue with Revit server that a haven't seen documented. I'm wondering is you have any ideas:
The client workstation is able to ping both local and central server.
The client workstation is able to access and manage RSAdmin for both loacal and central server.
The client workstation is able to have revit see the local and central server via the "connect to revit server"
The client workstation can see the folders on both the local and central revit server where the file will be saved.
The client workstation is able to enable workstaring and save the file to the local revit server in an appropiate folder. The Central server is mirroring that image as expected.
However
When the client goes to open the file on the local revit server the "Create new local" file tickbox is not available, and when you select "open" you get the message
"The revit server you are trying to access is not available dure to a server or network failure. if you have models from the Revit server open, save any changes locally and contact your administrator"
The interesting thing, if I change Revit to connect to the "Central Server" I can open the file with out a problem, but it takes time, as it opens it across the WAN.
Any ideas?
Thanks
Brian
However
Any ideas?
Thanks
Brian
