I've been searching the internet (and this forum) for about an hour now trying to figure this out. We had a bit of a messy set-up on our project. I am now adding the grid lines in and have had no problem until I try to edit a grid bubble to read "1". An error message continuously appears stating this grid already exists in the project and duplicate grid numbers are not allowed.
Here is what I've done to try to find this one grid line that is the only one I cannot find:
In plan, section, elevation and site, I have zoomed extent with the view clip window turned off
Same as above I have "revealed hidden elements" and again zoomed extent
Same as above I have checked to ensure no "temporary hide/isolate" commands are active
All other grids are showing fine, only grid "1" is missing.
Does anyone have any idea how I may perhaps "purge" this single grid line, or any way you know of that I may not have looked at the drawing to find the missing grid line?
Thank you!
Thank you!
