[06/2011] - Tilt wall tool
This is a sticky topic.
    Applies to: - All Verticals
    New Feature / Problem:
    Tilt / slant wall tool.
    Ability to specify angle from 90 degrees/plumb in the Wall Properties,
    or specify angle in real-time when live editing.
    Most if not all of our projects have walls which are at an inclined angle.
    In order to create tilted/slanted walls with the current tools we must:
    1. Create a Mass, then apply walls to the surfaces
    2. Create a custom family
    Neither of these are a good workflow.
    A built-in Tilt-Wall function would be much easier and faster.
    Workflow:
    Benefits:
    Faster and easier creation and editing of Tilted Walls
    Attachment comments:
    Cliff B. Collins
    Registered Architect
    Autodesk Expert Elite
    I was wondering when you would show up with this one Cliff.
    Jeff Hanson
    Sr. Subject Matter Expert
      Yeah--I've been too busy building tilted walls on real projects to post it! :crazy:
      Cliff B. Collins
        This one is so obvious that I didn´t even bother to post it But thanks to Cliff for reminding everyone that we still need this :beer:
          And the pics explain a little about WHY I have been asking for this for so long!!! LOL
          Time to head for the mountains--it's Friday!
          Cliff B. Collins
            Cliff, your walls are all crooked. No mountains for you. Get it fixed this weekend.
            Dan
              We had an architect at my last firm that was noted for saying "square it up"....that meant the design was too expensive if it had anything curved/tilited/angled/etc.
              Scott D Davis
              Sr. AEC Technical Specialist
              Autodesk, Inc.
              http://bit.ly/aboutsdd
                Scott, with all due respect, it´s fair enough if money is the limit, but it´s a bummer when the software becomes the limit
                  We got slanted columns, and they are almost useless!
                  Walls are currently pretty easily done with massing so I doubt Adesk will be rushing to add this feature. But it's worth having in the list still
                  Revit BLOGGAGE
                  http://www.revic.org.au
                    I think that slanted walls are modeled at a very early stage in the design phases. So I agree with the Firm logic when you have to deal with mass to achieve those walls.
                    Julien
                    P. DAC
