I am trying to edit an OOTB family to add a void extrusion that will allow me to plumb cut the end of framing members. I was able to successfully accomplish this with the OOTB W-Beam family, however now I am trying to do the same with the HSS and Nominal Lumber families and am running into problems. After I add the void extrusion to the family and insert into the project i get the warning "Can't create type" This only occurs after I align and lock the boundary of the void extrusion to the reference planes which define the families geometry. I am following the exact same procedure as I did for the W-Beam family, but I cannot get it to work.
Does anyone have any idea why as soon as I lock the void extrusion to the reference planes, why Revit cannot create the type when inserted into a project file? I've attached some images to help show the void extrusion I am adding.
