I have not done color fills and such in a few years and now I am trying to find where this is. My thought is that the color fill is with rooms and is only in RAC and I am using RST? Is this correct or where exactly can I draw different areas and pull a legend that gives them each a color defining what area they are?
Color Fill?
Used to be able to do a split surface in RS2009 although it seems the feature has been removed. This allowed you to put several different shades or hatch patterns onto the one surface, although I cant find this feature any more...
There is however, nothing to stop you using a filled region to shade an area, you could lock it to wall faces, or slab edges as appropriate and size would update with changes to the file.
I'm working on a large project and want to use the "Color Fill Legend". When I applied an area range I noticed that my largest space (95,000...December 19, 2012, 01:46 PM
Hi guys I got a faint issue when I put my areas in a rentable area plan or even in a gross building plan, well the problem is I cannot see the colors...August 28, 2013, 09:03 PM
Hi All,
The Color Fill Legend tool seems pretty easy in theory. I have it set to color by name, and in the "Edit Color Scheme"...July 5, 2013, 02:31 PM -
Hopefully this is something that is an issue I'm just totally brain dead as to how to fix at the moment...
I'm working on setting up Life...March 2, 2016, 01:46 PM -
Applies to: - Revit Architecture
New Feature / Problem:
We need the ability to edit Color Schemes after they are created. Currently,...-
Channel: 2011 Archive
September 28, 2011, 02:36 PM -
