Is there any way to get lighter shadows when rendering like you can lighten or darken shadows in the shaded views. I have the shadows set to the lightest rendering setting but I would still like them lighter. I had to go into photoshop to lighten up the column shadows. It would be nice to be able to get lighter shadows in the original rendering. I guess I could go with all artifical lights.
Lighter shadows
Set the time to dusk, dawn or night and then use "Adjust Exposure" to get a brighter "Exposure Value"
This will give you some very soft shadows :beer:Klaus Munkholm
"Do. Or do not. There is no try."
Thanks for the suggestions. My shadow setting in the exposure settings is at 0.1 which is the lowest. I had previously done a rendering with the time of day set to 2:30 am to get a very white rendering and soft shadows..it looked great on the computer screen, but when I printed it out it looked pretty faded without much punch. I think I might experiment with using artificial lighting instead of the sun. Thanks again.
Artificial lighting will also give you dark shadows, unless you plan to place multiple lights (artificial suns) to brighten up the shaded areas?
Seems like too much work, with a lot of trial and error before you´ll get a satisfying result. I think I´d go for post editing in PS
Good luck to you! :beer:Klaus Munkholm
If you are tired of washed out daytime renderings here is a little tip to try:
Just change the Exposure values in the adjust exposure dialog....-
Channel: Rendering and Gallery
February 3, 2011, 08:46 PM -
I was just exploring interior rendering in Revit.
In one of the rendering where i used Interior-Sun & Artificial...-
May 15, 2013, 12:34 PM -
Hi, i started loving revit more
this my second work on revit
i made adjustment on original output come from programme in exposure for...-
November 12, 2011, 05:37 PM -
Hi All,
We are producing some floor plans for a client proposal and we have done the whole, "slice the top of the building off and...August 25, 2011, 05:28 AM -
Hello everyone...
Really i`m new in Revit, I`m trying to make rendering but the output was unrealistic.
It seems i must...-
June 17, 2011, 11:46 PM -
Monumetric Footer In-screen
