I've run into this in the past but was reminded of it this morning. Using worksets, lets assume you encounter a user that has already borrowed something you want to work on. If you make an editing request but then close your local file before the request is resolved you can end up the borrower of an element, regardless of the fact that you chose to leave.
This happens if they just Synchronize with Central (SwC) instead of dealing with your editing request directly. The SwC resolves the request internally, which grants the your request, making you the new borrower, even though you aren't actively working in the project anymore.
This can be avoided if the person you make the editing request from just denies the request before using SwC. So...yes you can be the borrower even if, "But I didn't do anything and haven't even been in the file for awhile".
