We have a 6 1/4" slab --- 3 1/4" conc. on 3" composite metal deck.
When I cut a section, I should see the deck profile. If I move the section around the slab, sometimes I see the deck, sometimes I don't. Where do you think my metal deck is hiding? (even turned off ALL links and set to Discipline: Structural)
Any ideas?
Now it's just playing with me. The place I originally cut a section (where the deck profile *was* showing, the deck no longer shows... going to try to get screenshots to post...)
Got out of model, opened with Audit, and still having the issue...
Deck Plan A shows where I cut Section A; the deck shows as I expect.
Deck Plan B shows the EXACT SAME section cut, just moved to the left; my deck is not showing. I stretched the crop box up so I could see if the deck disappeared in the third floor also. This time it did not, but sometimes it does.
Any ideas?
