Gonçalo Feio "Ignorance, ignorance, sheer ignorance - you know there's no confidence to equal it. It's only when you know something about a profession, I think, that you're timid and careful." George Orson Welles
Revit's formula syntax is nearly identical to Excel's syntax from what I've seen. I'm far from an expert in either but learning one has helped out quite a bit with the other
Trying to get a Yes/No Parameter to work for the first time. This is only one example of what I would like to do, but I want to know if I can insert multiple...
What I'm trying to do is set up a family that if the family type parameter is set to A, then the yes/no parameter equals yes, and if the family type parameter...
