Placing different revit files into one file
    Hello there,
    I have 4 buildings which are to be at the same site. At the moment, they are in four different revit files. How can I place them all in one file and also specify their position and orientation within the file?
    Thanks
    Nash
    Hi Nash, basically you create a new project file, and use the Insert > Link Revit Command for each of the buildings. Now you can move/rotate those buildings/links within the new project as you like.
    You may also wan´t to read up on "Shared Coordinates" (Or "Shared Positioning" as it´s named in the help file)
