I'm after some advice on creating a composite panel wall type. Previously I have just used regions in elevations to indicate pattern/colour, but for this project it needs to be more flexible, as there will be changes to the colours and patterns and building too (straight walls though!).
Am I best off using a curtain wall system and a separate basic wall for SFS/plasterboard interior, or is there a way to use one single wall type?
I need to have 5 different colours, preferably assigned randomly. Should I create five different coloured panels in the family and use a visibility parameter to control the colour? It would be good to have some automation though, ideally with a greyscale image. Is this possible (without being a programmer!)? I did come across an old post about this, but it didn't explain how to go about it.
I'm a bit simple, so some clear steps or links to tutorials would be appreciated.
Thanks for your help.
Mark
Mark
