Ran across a recent situation where a good number of units were modelled as linked project files and combined into a "master" file. This master file was then linked into another model. As attached links that meant they would automatically show up as long as the source file was "found" (in a folder it could find).
It may have seemed like a good idea when they started, but the down side is nearly zero control over the nested linked units. About the only way to control what they look like is if every (and I mean every) sort of view configuration you might need in other files that host the combined file are preset in the "master file". The display of nested links can be configured to use the Linked File settings. Unfortunately, this is hard to really accomplish because we might not be able to imagine everything that will need to be done. That means an awful lot of back and forth to get it all to work.
My recommendation? Don't go there...
