[All Verticals] - Extend the width of the active workset display
This topic is closed.
    Applies to: - All Verticals
    New Feature / Problem:
    Naming conventions are meant to ease navigation and provide clarity. Hence, many have taken to naming worksets in a particular defined way to achieve this. The Active workset display (on the Collaborate Tab and bottom centre of screen) is usually filled with a 'Not Editable)' prefix, which consumes half the width.
    What is the value in having an active value displayed if you can't read the thing? This is such a clear-cut, easy-to-remedy request. After the debacle of the 2010 UI implementation, you'd think Autodesk would consider the UI a little more carefully now...
    As above.
    Workflow:
    Users could actually see the extents of their workset names within the active workset dropdown/displays.
    Benefits:
    Attachment comments:
