Someone help me - I think I'm losing my mind.
I've got some 4'-0" high walls that still need to display their cut pattern in a plan view. So I set the cut plane at 3'-0". But the short walls don't show up as being cut. I tried playing around with lots of varying settings, but the only way I could make the cut pattern show up was to change the height of the wall to 6'-0". Anything 6'-0" or taller, the cut pattern shows up just fine. Anything below that, it doesn't show up at all.
I figure there is probably something obvious that I am overlooking, but I am completely out of ideas as to what I'm doing wrong here.
