Duplicate Dependent Views
    Guys is it possible to duplicate the parent and duplicate views altogether?
    One user has created parent and dependent views for say the ground floor plan and is the 'owner' of that view/s. I'd also like a copy of both the parent and dependent views so that I can modify for a different plan layout of the same level.
    Is this possible?
    Duplicate your parent view as you normally would. Then right click on the original view that has the dependant views and select "Apply dependant views". You can apply the dependent views to more than just a duplicate of the parent too, allowing you to have the same crop regions etc on multiple levels.
    Michael
    Canberra, Australia
      Exar sensational, thanks so much. This will help keep consistent dependent views/sheets across all users in our project. I have one last question, how I can apply those dependent views AND keep their detailing? What I am hoping we can do is create master cropped dependent views, add grid dimensions and coordinates and then all other users can simply create copies of them and we all have the same cropped view, dimensions and coordinates. Is this possible, if not what's the best way to achieve it? Thanks again.
        I am trying to apply dependent views to a stand alone view but only two views are listed when i select the apply dependent view option. I have many other views that the dependents could be applied to. But none of them show up on the list and i dont know why.
