When placing a detail callout you will need to select the view to be referenced and then proceed to place the callout bubble. My question is; Is it possible to place only the callout head and not the leader?
We generally have struggled with this by simply making the leader as small as possible and getting it to be almost completely hidden by the callout bubble head. It's just frustrating that there seems to be no way around this problem.
FYI, we are working in Revit structure 2012 primarily at this point (although we will be moving quickly into 2013).
Does anyone have any tips or tricks for this?
Thank you.
Thank you.
